1 year of RTK corrections included / 1 year of RTK corrections included / 1 year of RTK corrections included /
Professional RTK Corrections, built into your Reach receiver
Activate in seconds and forget about complicated setups and managing credentials.
What is Emlid Corrections?
The missing piece that makes your setup complete.
Emlid Corrections is an RTK correction service that delivers centimeter-level GNSS positioning over the internet. It's integrated into Reach receivers and ready to use from day one.
Together, your receiver and Emlid Corrections become a single, complete tool. Everything you need to reach centimeter accuracy is already in the box.
Why Emlid Corrections
Zero setup
No extra steps, no base station, no more “who is using which account” questions. You grab a receiver with Emlid Corrections and it just works.
Consistent high accuracy
With a single base station, you lose precision as you move away from it. Emlid Corrections uses a network of reference stations, so your solution quality stays the same across your entire work area.
Predictable costs
Each Emlid Corrections license is tied to one receiver. No shared accounts, no unexpected overages — just predictable costs across your whole fleet.
Securing the best accuracy possible
1–2 cm accuracy
Professional-grade precision, consistent across the entire coverage area. Power on, connect to cellular, and get a centimeter-accurate fix. No base station, no third-party NTRIP subscription to configure, no radio links to set up.
VRS engine
VRS engine
Traditional RTK requires a physical base station nearby to deliver accurate corrections. Emlid Corrections uses VRS technology to create a virtual one at your location — so you get centimeter accuracy anywhere in the coverage area, without the extra hardware.
Professional reference station infrastructure
Emlid Corrections is powered by Point One Navigation’s network with thousands of global reference stations. This secure, extensive network ensures high precision alongside unparalleled speed and consistency.
Built in-house
All base stations are designed and manufactured in the USA and EU to deliver long-term durability.
High-security sites
The stations are placed in access-restricted locations and protected from unauthorized access.
Survey-grade install
Each base is professionally deployed and precisely calibrated to provide consistent correction data.
Network Intelligence
With full ownership and operation, Point One is able to embed root-level observability and OTA updates.
Compatible with
Reach RS4 Pro
Your first year is on us
Reach RS4 Pro
Visual stakeout and remote point capture for faster and safer work.
Explore
Effective teamwork with accuracy that fits in your pocket.
Explore
Reach RS4
Reach RS4
Ultimate precision, even in the most challenging conditions.
Explore
Reach RS3
Reach RS3
Multi-band RTK GNSS receiver with tilt compensation
Explore
Reach RS2/RS2+
Reach RS2/RS2+
Reach RX
Reach RX
Compact RTK network rover
Save 46% with the 3 year offer
1–2 cm accuracy
Reach receivers1 come with a full year of Emlid Corrections included — no credit card, no commitment. Just activate in Emlid Flow and start working.
$699 / per year
or $1,199 / for 3 years
Up and running in three steps
Step 1
Connect your receiver
Power on your RX2, RS4, or RS4 Pro and open Emlid Flow on your phone.
Step 2
Tap Emlid Corrections
Make sure your phone is connected to the internet. Select Emlid Corrections as your correction source.
Step 3
Start working
Your receiver connects to the network and reaches centimeter accuracy in seconds. That’s it.
Coverage
Not in your region yet?
Lock-in 3 years of savings
Your first year of Emlid Corrections is included with your Reach receiver1 — no credit card, no commitment. Each license is tied to one device. No shared accounts, no surprises.
Not satisfied? We’ll refund your purchase — no questions asked.2
First year is free
When you’re ready to continue:
1-year top-up
Renew anytime
$699
BUY
FAQ
Which Emlid models support Emlid Corrections?
Emlid Corrections is fully compatible with Reach RS4 Pro, RS4, RX2, RS3, RX, and RS2/RS2+. All these models come with a free first year.
What is the refund policy for Emlid Corrections?
If you are not completely satisfied with the service, you can request a refund within 2 months of purchase and still keep your free first year.
Base station or Emlid Corrections?
Both are valid approaches. A base station gives you full independence from internet connectivity and is great for permanent or semi-permanent setups. Emlid Corrections is ideal when you need to move between job sites, work across regions, or simply want to skip the base station logistics entirely.
Do I need an internet connection?
Yes — Emlid Corrections delivers corrections over the internet, so your phone needs to be online while working. A standard mobile data connection is sufficient.
Does it work with third-party receivers?
Emlid Corrections is currently available for Emlid RX2, RS4, RS4 Pro, RS3, RX, and RS2/RS2+.
Can I still use radio and regular NTRIP?
Absolutely. Emlid Corrections is one of several correction input options in Emlid Flow — you can switch between correction sources anytime.
Can I transfer it to another device?
Each license is tied to one device serial number and cannot be transferred. If you need corrections for multiple receivers, each requires its own license.
Have a question
before you buy?
Toll Free: 888-454-1916
¹ — Emlid Corrections is compatible with Reach RS4 Pro, RS4, RX2, RS3, RX, and RS2/RS2+, all of which include a complimentary first year.
² — If you’re not satisfied with the solution, you can request a refund within 2 months from the date of purchase. Your first free year will remain active.
