Drone Mapping with Emlid RTK Receivers
Black friday Cyber Week /
Save big /
Dec 1-8
Cyber Week Save big. December 1-8.
SHOP THE DEALS
RTK drone mapping with Reach receivers
Complement and enhance your RTK workflows with Emlid's high-precision receivers and software.
RTK is a technique that gets your drone mapping centimeter-level accuracy
It requires two devices: a base and a rover. In RTK drone mapping, the drone acts as the rover, which needs the base — a GNSS receiver.
Below is a walkthrough of all the workflows you may face working in RTK drone mapping and how our RTK ecosystem covers you on that.
Perfect base
for DJI, Autel, and other RTK drones
Reach receivers will seamlessly integrate with your drone, providing centimeter-level precision in all conditions.
Whether you are conducting a drone survey in urban areas or remote locations, Emlid's RTK base station ensures precision with the aid of advanced mapping software.
When you have internet
in the field
Your drone can receive corrections from the Reach base
via the NTRIP protocol. Connect your drone and base with the free
Emlid NTRIP Caster, and off you go.
When you're
out of cellular coverage
You can work with Reach RTK base even if you have "No Service" on your phone. Reach has the Local NTRIP Caster feature that provides NTRIP over Wi-Fi. All you need to do is connect your drone controller to Reach's network.
Reach receivers
are designed to work in cold, heat, rain,
or all of the above
  • Functions in -20 to +65 ºС
    Your base is capable of working in an incredible range of temperatures; it isn’t afraid of heat or cold.
  • Water and dust resistant
    Reach RS2+ is IP67-rated. All the unit’s connectors are completely sealed and protected with silicone plugs.
  • Up to 22 hours battery life
    Built-in industrial battery that can be charged via USB, just like your cell phone, is perfect for extended drone surveys in remote locations with limited power sources.
Explore Emlid receivers
Reach receiver in extreme conditions Reach receiver in extreme conditions
Drone data
post-processing
If you can’t establish the real-time connection between the base and the drone in the field, you can still update images with precise coordinates.
Our free Emlid Studio has a drone data processing option and supports all drones that provide MRK timestamp files.
Verify accuracy with ground control points
Ground control points for drone mapping help ensure your map meets accuracy requirements. RTK drones reduce the number of ground control points needed, but don't eliminate them completely.
Reach RS3
Acts as a base and a rover
If you already have a Reach base for your RTK drone, you can collect ground control points by connecting it to the NTRIP network or another receiver.
Learn more about GCPs for drone mapping:
How different industries use Reach RX:
New to drone mapping?
Ask a question
Drone mapping with Reach across industries
Volume Measurement with DJI Phantom 4 and Reach RS+
Isaac Vazquez Flores, Mining Engineer at Dromine, Mexico
Reach RS+ allowed us to quickly collect GCPs before drone mapping with Phantom 4 and helped to carry out precise volume measurements of the feldspar stock. The results obtained with a drone are identical to one obtained with a total station.
Development of an avalanche monitoring system
Thor Veen, CSO, Aeria, Canada
Aeria team used Reach RS2 units to place ground control points. This data helped the team to develop an avalanche monitoring system in the north of Pemberton, British Columbia.
Mapping the extent of invasive seagrass
Corbin Kling, North Carolina State University, USA
Researchers from North Carolina State University placed GCPs with Reach RS+ for mapping invasive seagrass extent. The project was aimed at developing innovative options for habitat restoration and resistance to harmful invasive seagrass.
3D modeling of an irrigation system
СampoDigital, Chile
With the help of Reach RS2, СampoDigital team placed ground control points for the drone flight in Osorno, a famous center of agriculture and cattle farming in Chile. Then, based on the collected data, they made a 3D model of the area for the irrigation project.
Mapping Iceland Glaciers
Jurijs Ješkins, the researcher at the faculty of Geography and Earth Sciences, University of Latvia
We used two Emlid Reach RS, one as a base and the other as a rover, and were surprised by the good performance and long battery life in very windy, wet, and cold conditions.
Drone mapping of gully erosion
Mangoesmapping, Australia
Mangoesmapping team used Reach RS+ to place GCPs for a drone mapping of gully erosion. The project was to evaluate the effectiveness of erosion minimization methods and reduce a negative impact on water quality on the Great Barrier Reef.
Updates
Do you want to receive news from us?
Subscribe to our newsletter.
Have a question?
Ask our team
Pre-sale support:
Toll Free: 888-454-1916
