Complement and enhance your RTK workflows with Emlid's high-precision receivers and software.
Your drone can receive corrections from the Reach base
via the NTRIP protocol. Connect your drone and base with the free
Emlid NTRIP Caster, and off you go.
You can work with Reach RTK base even if you have "No Service" on your phone. Reach has the Local NTRIP Caster feature that provides NTRIP over Wi-Fi. All you need to do is connect your drone controller to Reach's network.
Your base is capable of working in an incredible range of temperatures; it isn’t afraid of heat or cold.
Reach RS2+ is IP67-rated. All the unit’s connectors are completely sealed and protected with silicone plugs.
Built-in industrial battery that can be charged via USB, just like your cell phone, is perfect for extended drone surveys in remote locations with limited power sources.
Do you want to receive news from us?
Subscribe to our newsletter.
Direct Dial: +1 817 865 3334 (ex. 101)
