Reach RX
Pocket-sized RTK rover.
Perfect for GIS, utility inspection, landscaping, and more.
Now on iOS
Buy
250 g
Compact and powerful
Centimeter accurate data
Tracks GPS / QZSS / Galileo / GLONASS / BeiDou. Gets a FIX in up to 5 seconds.
Just add NTRIP
Reach RX is a network rover. Gets corrections from any NTRIP service in RTCM3. No settings to get wrong.
No training is required
Saves time for professional surveyors and non-surveyors—no additional setup.
iOS & Android
High-precision mapping
with Reach RX
Survey
with Emlid Flow
A mobile app designed
for efficient land surveying.
  • Data collection and stakeout
  • Verified coordinate systems library
  • SHP, DXF, CSV, and KML
  • Inverse & Traverse
  • Survey codes
  • Localization
  • Auto collection
Integrate
with 3rd-party applications
Reach RX uses Bluetooth and integrates
with surveying apps as a GPS receiver.
  • ArcGIS Field Maps
  • QField
  • MicroSurvey FieldGenius
  • Global Mapper
  • Mergin Maps
  • Avenza Maps
Robust by design
Withstands -20 to +65ºC
Reach RX works in the coldest winters and hottest summers.
16 hours on one charge
2 days of work in less than 3 hours of charge. It can be charged from any USB port or power bank.
Waterproof
The Reach RX is well protected from water and dust with an IP68 rating and silicone plugs.
Use cases
Trusted by professionals
Responsive image
Drone mapping
Rory Gillies and Shetland Flyer Aerial Media
Rory, an aerial mapping and GIS specialist from the UK, and his team shared their experience collecting ground control points (GCPs) in a hillside area. They set up a Reach RS2+ base connected to the internet via a SIM card and transmitted corrections to the Reach RX using the free Emlid NTRIP Caster. The precision of the corrections allowed him to conduct several stakeouts and verify the locations in QGIS with high accuracy.
...read more
Responsive image
Construction Design
Joe Lawson
Joe, who runs a surveying services company in the UK, utilized the Reach RX GNSS rover, a FARO scanner, and a total station to pinpoint the location of a wall in a river for the design of a new eel pass. He subsequently processed the survey data using 3D modeling software.
...read more
Construction Inspection
Brent Wiebe
Brent, a surveyor from Canada, specializes in topographic surveys and construction layouts. He used the Reach RX to verify the placement of screw piles for a concrete building's foundation and to mark out future roads and rights-of-way for the building and its utilities.
His setup included the Reach RX GPS receiver and Reach RS2, using the RS2 as a base to stream corrections via Emlid Caster, ensuring uninterrupted service with flawless results. The data collected at the job site was later processed using software programs like AutoCAD Civil 3D, QGIS, and Revit.
...read more
Underground utilities
SwiftNav, Deutsche Telekom, ITS Geo
Swift Navigation offers the Skylark™ Precise Positioning Service. The service uses the NTRIP protocol and satellite data to provide RTK corrections worldwide. It's fully compatible with Reach RX, enabling centimeter-level accuracy and fast fix times.
In a recent Deutsche Telekom fiber deployment project, the integrated solution was used to achieve precise positioning. Workers used Reach RX receivers and the Skylark service along with the GeoAce app to accurately map trench lines, allowing for safe digging without the need to involve licensed surveyors. This setup ensured high accuracy and efficiency, demonstrating the effectiveness of the combined technologies in a challenging environment.
...read more
Road Design
Michael Lambert
Michael, a virtual design and construction manager from Texas, needed to conduct a topographic and planimetric survey for a Williamson County road project to develop a 3.5-mile rehabilitation and extension design. He used the Reach RX to gather existing features like flowlines and surface utilities in the construction site and set ground control points for drone mapping. To create a planimetric map, Michael processed the collected data using Carlson and SimActive software.
...read more
Use Reach RX with your own base and Emlid Caster
Don't have an NTRIP station near you for your GNSS RTK setup? Run your own NTRIP service with your own base and free Emlid Caster. You can use any GNSS \ GPS receiver with NTRIP and RTCM3 support. For example, Reach RS3.
Get your Reach RX
  • – Reach RX
  • – USB Type-C cable
  • Buy
2-7 days by FedEx, UPS
Need help?
Tutorials
Watch quickstart guides and comprehensive feature overviews.
The Emlid support team regularly updates all materials based on the most frequently asked questions and popular workflows.
Lifetime support
To get help with general questions and configuration, contact our Application Engineers via Facebook or E-mail.
Community
Join the Forum and Facebook User Group to get in touch with the Emlid team, get tips and advice, and connect with Emlid users from around the world.
Mechanical
  • Dimensions 172 x 51 x 51 mm
    (6,77 x 2,00 x 2,00 pol)
  • Mount 5/8”-11 UNC
  • Weight 250 g (8.81 oz)
  • Operating tº -20 to +65 ºC (-4 a 149 °F)
  • Ingress protection IP68 (maximum
    depth of 1.5 meters
    up to 30 minutes)
Electrical
  • Autonomy Up to 16 hrs
  • Battery Li-Ion 5200 mAh,
    3.6V, 18.72 Wh
  • Charging USB Type-C, 5V 2A
  • Certification FCC, CE, IC
Positioning
  • RTK H: 7 mm + 1 ppm
    V: 14 mm + 1 ppm
  • Convergence time ~5 s typically
Connectivity
  • Communication interface Bluetooth 4.2
    (BR/EDR + LE)
  • Ports USB Type-C
Data
  • Input data format RTCM3
  • Input data protocol NTRIP
  • Position data format NMEA
  • Signal tracked GPS/QZSS L1C/A, L2C,
    GLONASS L1OF, L2OF,
    BeiDou B1I, B2I,
    Galileo E1B/C, E5b
  • Number of channels 184
  • Update rate 5 Hz
Updates
Do you want to receive news from us?
Subscribe to our newsletter.
Have a question?
Ask our team
Pre-sale support:
Toll Free: 888-454-1916
