Free standard shipping across the United States.
Visit Emlid US Store.
REACH M+ and M2
Reach – PPK module
for drone mapping
Deliver centimeter-precise maps with Reach on a drone. Map wherever you need with less ground control points.
Starting from $329
Choose a receiver
PPK Mapping in the Arctic. Water and Ice
Research Laboratory, Carleton University
Positioning with centimeter precision in RTK and PPK
Reach M+
Single-band
Baseline up to 20 km in PPK
$329
Buy
Reach M2
Multi-band
Baseline up to 100 km in PPK
$649
Buy
Precise georeferencing
Save your time and reach remote areas
Reach onboard a drone allows you to drastically cut the number of ground control points (GCPs) this simplifies the setup process on-site and accurately maps even remote areas.
Why camera synchronization
is so important?
Usually, the autopilot triggers the camera and records the coordinate it has at that moment. When the drone is flying at 20 m/s and GPS works at 5 Hz, that means your autopilot will only have position readings every 4 m, which is not suitable for precise georeferencing. There is also always a delay between the trigger and the actual moment the photo is taken.
Reach eliminates
the delay
Reach solves the problem of positioning by connecting directly to the camera hot shoe port, which is synced with the shutter. The time and coordinates of each photo are logged with a resolution of less than a microsecond. This method allows GCPs to only be used to check your accuracy.
How to get
started?
Connect Reach to a hot shoe port on a camera
1.
Every time a photo is taken the camera produces a pulse on a flash hot-shoe connector which is synced to a shutter opening.
Fly a drone, Reach will record photo events
2.
Reach captures flash sync pulses with sub-microsecond resolution and stores them in a raw data RINEX log in the internal memory.
Download logs from Reach and base station
3.
After the flight, get the RINEX logs from your airborne Reach module and a base station (Reach RS, CORS or another receiver).
Process logs and get a file with geotags of photos
4.
of photos
Process RINEX files using Emlid Studio. The file is created with precise coordinates of the photos and can be used for georeferencing.
Compatibility
To ensure smooth synchronization of Reach and a camera, we recommend you use the Reach M+/M2 hot shoe adapter. You can get it in Online Store with UAV kit or separately.
Our PPK modules are fully compatible with most cameras with hot shoe including
  • Sony A6000
  • Nikon D3200
  • Canon EOS 4000D
  • Canon EOS 700D DSLR
  • Ricoh GR III
  • Sony Alpha A7R III
  • Samsung NX1000
Android and iOS
Comes
with Emlid Flow app
The most user-friendly software for data collection that is available both for Android and iOS. Supports thousands of coordinate systems and is translated into multiple languages. With Emlid Flow, you can control all the features of Reach receivers, such as setting up a base station, logging RINEX data, and configuring NMEA output.
Camera
control
Reach can trigger cameras as well as register events. The event mark feature is a must for aerial mapping as it allows the precise time when the shutter was activated to be registered.
Simple log
management
Logs are automatically recorded directly to RINEX in the internal memory. View
a list of the logs and download them using the Emlid Flow app.
Monitoring
data
Emlid Flow shows current satellite levels, your location on a map, and much more.
Reach is designed for harsh conditions Reach is designed for harsh conditions
Engineered
to be tough
Reach receivers are designed to work in challenging conditions, even in frosty and dusty areas, under the burning sun
-20 to
+65 ºС
We extensively tested Reach M+/M2 in conditions that simulate coldest winters and hottest summers.
REACH M2 and REACH M+
Choosing between
Reach M+ and
Reach M2
Reach M+
and
Reach RS+
If you work within short baselines, then Reach M+ is an optimal choice.
Reach M2
and
Reach RS2+
Provides robust performance and quick initialization, allowing work on long baselines.
RTK
Up to 10 km
Up to 60 km
PPK
Up to 20 km
Up to 100 km
Time to fix
1-2 min
5 sec
Frequency bands
Single-band
Multi-band
RINEX logging
update rate
Up to 14 Hz
Up to 10 Hz
Reach M+ UAV mapping kit
Reach M+, Reach RS+
and GNSS antenna
$1397
Buy
Reach M2 UAV mapping kit
Reach M2, Reach RS2+
and GNSS antenna
$3496
Buy
Reach M+
Reach M+
Single-band Baseline
up to 20 km in PPK
$329
Buy
Reach M2
Reach M2
Multi-band Baseline
up to 100 km in PPK
$649
Buy
User reviews
Luke Wijnberg
CEO of 3DroneMapping
As a brief synopsis of the results, the maximum deviation of points was no more than 0.09m in all axes. This is an incredible result given the fact that the average pixel size of the resulting imagery was 0.045m.
Tuffwing
Drones for Aerial Mapping
Tuffwing performed integration of Emlid Reach RTK to enable precision maps to be made without the use of GCPs. The lateral RMS error achieved is just 4cm according to the Pix4D quality report.
Event 38
Drone Manufacturer
With the M2 integrated into the E400 mapping drone, we created an orthomosaic and DSM with 0.98 cm horizontal and 2.29 cm vertical RMSE. The M2 beats all the other GNSS solutions we have used in the past.
Specifications
Mechanical
  • Dimensions 56.4 x 45.3 x 14.6 mm
  • Weight 35 g
  • Operating tº -20 to +65 ºC
Electrical
  • Power supply voltage on
    USB or JST-GH connectors 4.75 - 5.5 V
  • Antenna DC bias 3.3 V
  • Typical current consumption @5V 300 mA
Positioning
  • Static horizontal 4 mm + 0.5 ppm
  • Static vertical 8 mm + 1 ppm
  • Kinematic horizontal 7 mm + 1 ppm
  • Kinematic vertical 14 mm + 1 ppm
Connectivity
  • LoRa radio (sold separately)
  • Frequency range 868/915 MHz
  • Distance Up to 8 km
  • Wi-Fi 802.11 b/g/n
  • Bluetooth 4.0/2.1 EDR
  • Ports USB, UART, Event
Data
  • Corrections NTRIP, VRS, RTCM3
  • Position output NMEA, LLH/XYZ
  • Data logging RINEX with events
    with update rate up to 10 Hz
  • Internal storage 16 GB
  • Signal tracked GPS/QZSS L1C/A, L2C
    GLONASS L1OF, L2OF
    BeiDou B1I, B2I
    Galileo E1B/C, E5b
  • Number of channels 184
  • Update rates 10 Hz GNSS
  • IMU 9DOF
Mechanical
  • Weight 35 g
Electrical
  • Power supply voltage on USB
  • Typical current consumption @5V 250 mA
Positioning
  • Static horizontal 5 mm + 1 ppm
  • Static vertical 10 mm + 2 ppm
  • Kinematic vertical 14 mm + 2 ppm
Connectivity
Data
    with update rate up to 14 Hz
  • Internal storage 8 GB
  • Signal tracked GPS/QZSS L1, GLONASS G1,
    BeiDou B1, Galileo E1, SBAS
  • Number of channels 72
  • Update rates 14 Hz/5 Hz
  • IMU 9DOF
Have a question?
Ask our team
Email us at info@emlid.com  or fill in the contact form. Our application engineers will reply to you within a working day
(9:00-18:00 CET).
This site is protected by reCAPTCHA, and the Google Privacy Policy and Terms of Service apply.
