Post-process data from GNSS receivers and RTK drones
Upload RINEX and UBX logs to get precise coordinates and geotagged images.
Save big on all gear, while still in stock!
Shop NowUpload RINEX and UBX logs to get precise coordinates and geotagged images.
Update images from an RTK drone with precise coordinates. For example, if you have lost the real-time connection between the base and the drone in the field.
Emlid Studio supports RTK drones that provide time stamps in MRK format, including DJI RTK and Autel Enterprise series.
DJI RTK, Autel
Enterprise series,
and others
Post-process logs from a base and a GNSS module to add precise coordinates to images. This workflow is for drone pilots who have Reach M2/M+ on a drone for PPK mapping.
The Stop & Go with Emlid Flow feature allows you to get precise coordinates of separate points that were collected without a real-time correction link.
For example, if you need to collect ground control points, but there is no internet coverage for NTRIP and you can't use radio.
