NTRIP Caster Land Survey Software | Emlid
EMLID NTRIP CASTER
Stream RTK corrections
from your base to the rovers over the internet
Emlid Caster works with Reach and any other
receivers with NTRIP support. The service
is available for free and works worldwide.
Emlid NTRIP Caster
Emlid NTRIP Caster
Your setup
Emlid Caster allows you to set up your own NTRIP base for an RTK drone (DJI, Autel, etc.), tractor, or another GNSS receiver.
Our Caster is a web application. It means you only need a base, GPS rover, and connection to the internet. Just make sure both base and rover works with the same format.
Formats RTCM3, CMR,
and others
How Emlid Caster works
Just sign up and start using
The Emlid Caster is extremely easy to use. Just sign up and your NTRIP credentials will be generated automatically. You can start using the caster immediately. Connectivity is limited to 5 bases and up to 10 RTK rovers at the same time.
Just sign up and start using the Emlid Caster
User reviews
  • Emlid Caster makes using NTRIP convenient and easy to set up. Corrections were sent from the Reach M2 to Emlid Caster, which had 100% uptime! There is no easier way to own a base station.
    Tynell Dake
  • Nice stuff! Looking forward to using it, preferably with a DJI M300 using the RS2 as a base. Super nice functionality and awesome interface! Well done!
    Christian Grüner
  • The excellent free app, you will no longer depend on paying for a CORS network service. Activate whenever and wherever you want. Cool!!!
    Geolaboratorio Topografia Geodesia
  • Works like a charm.
    Dave Pitman
Set corrections
on your receivers
Enter NTRIP credentials on
your base station and rover
Workflow for Reach receivers is described on the right. If you have another device, email us at support@emlid.com. Our application engineers will tell you how to work with the credentials.
On a base
  • Go to Reach settings.
  • Go to Correction output.
  • Select NTRIP.
  • Fill in the credentials of
    your mount point.
On a rover
  • Go to Correction input.
  • Select NTRIP.
  • Fill in the credentials for
    your rover.
To work with NTRIP, you need to connect your receivers to the internet
BLE connection
Connect your Reach to Emlid Flow via Bluetooth. It will then automatically use the internet connection from your mobile device.
SIM card
If your Reach model supports SIM cards, insert one and enable mobile data in Emlid Flow.
Wi-Fi
Turn on mobile data on your smartphone and share it via a Wi-Fi hotspot. The Reach will then connect to your network and get internet access.
For more information about specific Reach models, please check our docs.
Have a question?
Ask our team
Pre-sale support:
Toll Free: 888-454-1916
