Scanning kit to get
high-precision 3D models
in minutes
You can just walk around the object while the scanning kit does the work for you
Underground utilities
Create open trench models to document and calculate volumes accurately.
Construction
Monitor as-built progress with accurate and quickly captured 3D models.
Drone mapping
Supplement your drone mapping results with terrestrial data for objects hidden from the drone's view.
Forensics
Build accurate 3D collision scenes and add detailed measurements in real-time.
High-precision GNSS hardware by Emlid
Centimeter-level accuracy with NTRIP
Reach RX2 works with any correction network or GNSS base that broadcasts RTCM3. It obtains a fix in less than 5 seconds, even in challenging conditions.
Protected from water and dust
Rain is no problem. The RX2 is IP68-rated and waterproof to a depth of 1.5 meters. The connector is sealed with a silicone plug.
16 hours on one charge
2 days of work for less than 3 hours of charging. You can charge on-the-go from any USB port or power bank.
Works as a standalone rover
Remove your RX2 from the handle, attach it to a survey pole, and you're ready to collect or stake out data just like with a traditional GNSS receiver.
Powerful photogrammetry software by Pix4D
1. Capture data .png)
The PIX4Dcatch mobile app with integrated Reach RX2 allows you to capture precise and geotagged data using your smartphone camera and LiDAR.
2. Process data
Automatically upload your images to PIX4Dcloud for seamless processing OR import your images from your phone to the PIX4Dmatic desktop app using the PIX4Dcatch processing template. If necessary, you can even merge terrestrial and drone data.
3. Export to GIS, CAD, or BIM
Mark your assets on PIX4Dsurvey as vectors in the point cloud and export them as DXF (for CAD) or SHP (for GIS).
Get your kit
Pix4D & Emlid Scanning kit
- 1. Reach RX2 receiver
- Type‑C cable
- 2. Emlid Scanning Kit
- Emlid Handle
- Leash
- Allen key 3 mm
- Carrying case
- PIX4Dcatch
$4,300
Updates
Do you want to receive news from us?
Subscribe to our newsletter.
Have a question
before you buy?
Direct Dial: +1 817 865 3334 (ex. 101)
