us
REACH RS+
REACH RS+
Single-band RTK GNSS receiver
For surveying in RTK and PPK modes.
Comes with a mobile app.
Buy
Broad
connectivity
Wi-Fi, Bluetooth,
RS-232, USB
Dual-feed
antenna
High performance dual-
feed antenna with large
ground plane.
RINEX
logging
Update rate
is up to 14 Hz.
LoRa
radio
Up to 8 km connectivity
at 868/915 MHz.
iOS
Survey with Emlid Flow
and manage data with Emlid Flow 360
Emlid Flow is a mobile app for iOS and Android. It handles all the fieldwork—receiver settings, data collection, coding, linework, and stakeout. All survey data is in sync with the cloud-based service Emlid Flow 360, which allows you to access your projects from your browser and manage survey data and code lists.
Standard
Collect and stake out points
Use any coordinate system you need
To create a project for data collection, choose your coordinate system from the library or enter its parameters manually. The app supports thousands of coordinate systems, projections, grids, and geoids.
In the stakeout mode, the app displays East-North and straight-to-line distances and supports cut and fill indications. A close-up alignment mode helps you to center precisely above the point.
Coordinate systems based on
WGS84, NAD83,
GDA2020, and others
Collect and stake out lines
Create linework on the go, start new
lines, and continue collecting
existing ones
You can either use predefined geometry types or a full-blown code library. The linework is displayed right away, so you can always see how your project is progressing.
During the stakeout, you can easily navigate to a line, and stake it out with an offset and with a chainage.
Coding
Quickly switch between different object codes as the whole library is at your fingertips at all times
To measure and describe objects, upload your custom code library or use a built-in one with more than a hundred codes. Easily create new codes on the fly right in your survey project.
Work with satellite maps or any WMS source
Our responsive project view supports satellite imagery, as well as your own custom background map sources.
Standard
Manage your projects in the cloud
The Emlid Flow app is synchronized with the Emlid Flow 360 service. This allows you to create and access survey projects, manage coordinate systems, and export and import data using both the mobile app and the cloud service at flow360.emlid.com.
Export and import formats
CSV, DXF, and Shapefile
Manage your code libraries
Import your code library to Emlid Flow 360, and it is immediately available for your projects inside the Emlid Flow mobile app. No need to check if the latest version is on the collector, as it all syncs automatically.
The full list of features is available with the Survey plan.
Try it in Emlid Flow 360 for $25/month.
The basic functions are free
with the Standard plan.
Real-time position
Streaming in NMEA
Reach provides data in standard NMEA that is used by most GIS apps. Simply connect your device to Reach over Bluetooth or with a cable, and turn on “Position output” in Emlid Flow.
Compatible apps
FieldGenius for Android, ESRI Collector, QField and others
Reach can turn on and off automatically
Reach can turn on and off in sync with an external battery connected over RS-232. This helps when the power button is hard to reach, for example, if the receiver is placed on the roof of a tractor.
Position streaming
Interfaces
RS-232, TCP, Bluetooth
Log raw data
in RINEX
Record raw positioning data in RINEX format for further post-processing. Point collection and recording of raw data are independent processes and can be used simultaneously.
For post-processing, you can use our free
PPK software Emlid Studio.
Reach RS+ on a tripod
Marcelo Bernardin, Chile
NTRIP or another Reach as a base station
Reach RS+ needs a base station as a source of corrections. That’s a requirement for centimeter precision in RTK and PPK. The base might be another Reach RS+ receiver or an NTRIP service. VRS is also supported.
Reach RS+ works seamlessly with other Reach receivers over any link.
Input and output corrections
Interfaces
TCP, LoRa, Bluetooth,
RS-232, NTRIP
Formats
RTCM3
Max distance from a base
Up to 10 km in RTK
20 km in PPK
Reach RS+ is designed for harsh conditions
Reach RS+ is engineered to be tough
Frost, heat, and water — Reach can handle it all
Can be held 1 meter deep underwater for half an hour.
-20 to +65 ºС
Working temperature. Isn’t afraid of either heat or cold.
Up to 30 hours
Industrial LiFePO4 battery that doesn’t die when cold. Charges over USB from a powerbank.
Reach RS+ documentation
Tutorials
Quickstart guides and a comprehensive feature overview. Step-by-step tutorials covering the most common applications. Regularly updated by our support team according to the most frequently asked questions.
Emlid Community
Community forum
Share your project or ask any question on our community forum to get answers from experienced users and the Emlid team. Stories about using Emlid products from users all over the world.
Reach RS+
in Emlid Store
The Standard plan of Emlid Flow is available for free to all Emlid users.
Looking for more?
If you are looking for a multi-band receiver that works with a longer baseline and even in a blocked sky view, check out Reach RS2+.
REACH RS2+
$2499
REACH RS+
Looking for more?
REACH RS2+
$2499
REACH RS+
Frequency bands Multi-band Single-band
Time to first FIX Up to 5 sec 1-2 minutes
Positioning in RTK H: 7 mm + 1
pmm
V: 14 mm + 1
pmm
H: 7 mm + 1
pmm
V: 14 mm + 1
pmm
Baseline in RTK Up to 60 km Up to 10 km
LTE modem Yes No
Explore
Mechanical
  • Dimensions 145 x 145 x 85 mm
  • Weight 690 g
  • Operating tº -20 to +65 ºC
  • Ingress protection IP67
Electrical
  • Autonomy Up to 30 hrs
  • Battery LiFePO4 3.2 V
  • External power input 6–40 V
  • Charging MicroUSB 5 V
  • Certification FCC, CE
Positioning
  • Static horizontal 5 mm + 1 ppm
  • Static vertical 10 mm + 2 ppm
  • Kinematic horizontal 7 mm + 1 ppm
  • Kinematic vertical 14 mm + 2 ppm
Connectivity
  • LoRa radio
  • Frequency range 868/915 MHz
  • Distance Up to 8 km
  • Wi-Fi 802.11 b/g/n
  • Bluetooth 4.0/2.1 EDR
  • Ports RS-232, MicroUSB
Data
  • Corrections NTRIP, RTCM3
  • Position output NMEA, LLH/XYZ
  • Data logging RINEX with events
    with update rate up to 14 Hz
  • Internal storage 8 GB
  • Signal tracked GPS/QZSS L1, GLONASS G1,
    BeiDou B1, Galileo E1, SBAS
  • Number of channels 72
  • Update rates 14 Hz / 5 Hz
Have a question?
Ask our team
Email us at info@emlid.com  or fill in the contact form. Our application engineers will reply to you within a working day
(9:00-18:00 CET).
Pre-sale support:
Toll Free: 888-454-1916
