Carlson SurvCE Now Supports Reach RS!
We have great news for Carlson SurvCE and SurvPC users! From the SurvCE version 5.06, Emlid Reach RS is fully supported making connection workflow even easier!
To start collecting data with Reach RS rover using SurvCE launch the software, go to “GPS Rover” and select EMLID as Manufacturer.
Select EMLID as Manufacturer in SurvCE
In ReachView running on your Reach RS rover select position output via Bluetooth in NMEA format.
Select position output via Bluetooth in NMEA format ReachView
Then pair the data collector running SurvCE with your Reach RS receiver via Bluetooth.
Pair SurvCE with Reach RS via Bluetooth
Remember to enable Bluetooth in ReachView running on Reach RS.
Enable Bluetooth in ReachView
Select the receiver from the available devices list in SurvCE.
Select the receiver in SurvCE
If you are getting RTCM3 corrections from SurvCE select Bluetooth correction input.
Select Bluetooth correction input
That’s it, you are ready to go!
Carlson SurvCE is a complete data collection system for Real Time (RTK) GPS and Total Stations with in-field coordinate geometry. Carlson SurvCE is the data collection software, combining advanced functionality and ease-of-use.
If you are facing issues when pairing SurvCE / SurvPC and Reach RS, please report on our community forum!
Start using accessible Reach RS RTK GNSS Receiver for centimeter-accurate data collection!
With a variety of connectivity options Reach RS is an accessible and centimeter-accurate receiver compatible with different data collection software including MicroSurvey FieldGenius, Topcon MagnetField and survey apps for Android devices(Geomax X-pad Survey, Mobile Topographer, Autocad360, etc).
Learn more about Reach RS or buy now from our online shop or local dealer!
