Stop rework before it starts
A misplaced anchor bolt caught before the pour costs minutes. After, it can cost thousands — plus scheduling problems. Verifying work at every stage means mistakes get fixed when they're still cheap.
Emlid for QA/QC
Any crew member can verify work against the design directly in the field. Precise checks used to mean waiting for the right person with the right equipment. Now it can be done without stopping the job.
A receiver that doesn't sit on a shelf. Simple enough for anyone on site to pick up and use — most crews run their first checks in less than a workday.
Works on any iOS or Android device
Tilt compensation — no need to level the pole at every point
Zero setup — high accuracy out of the box
Covers multiple tasks on site — from stakeout to drone mapping
Seamless team collaboration — field and office work off the same data
A low cost-of-loss tool — built for the realities of a construction site
"People prefer using Emlid. The product is impressive and very user-friendly. It's easy to train new engineers on, without decades of experience."
Talk to our application engineers to find out how Emlid integrates with your workflow to save you time and money.
Talk to our team
One bad stage pushes every trade behind it. When your crew can check their own work before signing off and moving on, you stop the cascade before it starts.
Every check is timestamped, geolocated, and exportable. If a question comes up at closeout or during a claim, you have documented proof that the work was verified — and when, and by whom.
Emlid has a worldwide network of dealers and partners. Find one in your country for local purchase or hands-on help
Find a dealerOur team of Application Engineers is ready to help you with all issues and questions during setup and ongoing work with your device.
Send us a question via the contact form. For complicated issues, we arrange calls to speak directly with our clients.
A pocket-sized rover that's ready in seconds
Reach RS4 Pro
Full-kit receiver with AR stakeout and Visual Capture for hard-to-reach areas
Learn to build without waiting
Discover how you can speed up routine tasks
like anchor bolt checks and grade verifications with our products
Consult with our application engineers
to identify the right hardware and software setup for your site
Hear back in one business day
to discuss your project and schedule an online demo
Yes, for most site checks. Reach receivers deliver centimeter-level RTK accuracy, which covers anchor bolt and footing locations, grade verification, utility and curb alignment, and as-built confirmation. Vertical accuracy is typically about half as precise as horizontal, so for millimeter tolerances like finished floor flatness, a level or total station is still the right tool.
Anything in your DXF drawing — points, lines, and polygons. Crews import the design into Emlid Flow, measure in the field, and see the deviation from the design immediately. Common checks include anchor bolts and embeds before a pour, column and footing layout, curb and utility alignment, and finished grades.
No. Reach receivers are simple enough for foremen, field engineers, and superintendents to run routine checks themselves, and most crews run their first checks in less than a workday. Tilt compensation removes the need to level the pole at every point, so your survey team can stay focused on control and layout instead of verification requests.
The Reach RX2 is the better fit for frequent, quick checks, since it's a 280 g network rover that's ready in seconds wherever there's cellular coverage for NTRIP corrections. The Reach RS4 Pro is the better fit for complex sites, since it adds AR stakeout, Visual Capture for hard-to-reach points, and a built-in radio for sites without reliable coverage.
Every measurement in Emlid Flow is stored with its coordinates and timestamp, and crews can attach descriptions or photos for context. Data syncs to Emlid Flow 360 as it's collected, so project managers can review checks in real time and export records for closeout packages, inspections, or claims.
Yes. Reach receivers use industry-standard RTCM3 corrections, so they can work from a base station already on site, from an NTRIP service or Emlid Corrections. Field data exports in standard formats such as CSV, DXF, and SHP, so it moves into your existing CAD and project tools without a conversion step.
GNSS needs a clear view of the sky, so it's fastest on open sites — earthwork, foundations, slabs, utilities, and paving. Inside structures a total station is the better tool. Many crews use both: GNSS for open-site checks, and a total station once the building closes in.
