It is possible to connect to Navio’s onboard u-blox GPS module from u-center software. To do that ublox-spi-to-tcp application has to be run on Raspberry:
The utility is available from our GitHub Navio repository:
git clone https://github.com/emlid/Navio cd Navio/Utilities/ublox-spi-to-tcp make ./ublox-spi-to-tcp 5000
It will open port 5000 and will wait for a connection.
Open u-center, navigate to Receiver – Port – Network connection – New. Enter the IP address of your Raspberry:
You should see messages coming from the receiver in the Packet console as well as other visual data.
Dynamic model
Note to Navio Raw users – U-blox NEO-6T receiver is configured for stationary mode by default and it will loose fix if the antenna is moved. To change the mode open View – Configuration View – NAV5 and change Dynamic Model.
